LabWindows/CVI
problems using comport
First the history:
We have an stepping motor unit with serial comunication. The first
version of our comunication programm was DOS-based using "_inp" and
"_outp". It Worked fine!
We ported this Software to windos few years ago unsing the CVI low level
driver functions "inp" and "outp". It worked well with WinNT 4.0 a long
Time. It never worked with win2000 and now we have problems with WinNT
4.0 and fast Computers(maybe a timing problem). Now we try to use the
standard CVI com Functions (ComWrtByte...) and they work. But there is
still a problem: with same baudrate the comunication is about 5 times
slower as the version with "inp" and "outp".
Has anyone an idea how to solve this Problem?.
// InitSer
// Initialising.
// Typ | Parameter |IOR| Bedeutung
// unsigned long | iComNum | I |
// int | RETURN | R | 0 = ok | -1 = Error
int clsComI332::InitSer(long lBaud)
WriteLog(LOG_LEVEL_I332,"InitSer(%ld);",lBaud);
#ifdef CVI
int iRet;
iRet = OpenComConfig (iAttrComNo,"", lBaud, 0, 8, 1,30,30);
iRet = SetComTime (iAttrComNo,0.5); // 0.2 Sekunden
return 0;
#else
word BdDiv;
static int ComAdr[4] = {0x3f8, 0x2f8, 0x3e8, 0x2e8};
I332Err = 0; // testweise aus DOS-Version
I332_IFC = 0; // testweise aus DOS-Version
if (iAttrComNo < 1 || iAttrComNo > 2)
return (ParErr);
I332_IFC=iAttrComNo;
SerPort = ComAdr[iAttrComNo-1];
if (SerPort == 0)
return (IFCErr);
BdDiv = (word)(115200L / lBaud);
outp(SerPort+3,_inp(SerPort+3) | 0x80);
outp(SerPort+0,(byte) Lo (BdDiv));
outp(SerPort+1,(byte) Hi (BdDiv));
outp(SerPort+3,0x07); // Parameter 1N8
inp (SerPort); // Dummy-Read: Clr Receiver
return (0);
#endif
} // ENDE: Funktion InitSer
// CloseSer
// Zweck:
// close.
int clsComI332::CloseSer()
WriteLog(LOG_LEVEL_I332,"CloseSer();");
#ifdef CVI
CloseCom (iAttrComNo);
#endif
return 0;
} // ENDE: Funktion CloseSer
// XmtSer
// Comunicate
// char | cCode | I |
char clsComI332::XmtSer(char cCode)
#ifdef CVI
int iRet;
ComWrtByte (iAttrComNo, (int)cCode & 0xFF); //Write
iRet = ComRdByte (iAttrComNo); //Read
return (char)(iRet & 0xFF);
#else
clock_t tTimeOut, tDuration;
tDuration = CLOCKS_PER_SEC ; // Sekunde reicht
//* 20; // * 1 -> 1 Sekunde
if (I332Err != 0)
TL_MessagePopup("MotorCtrl",GetRS232ErrorString(I332Err),TL_ERR_CAT_INIT,TL_ERR_MOD_MOT_SMU2,TL_ERR_PRIO_NONE);
return (0);
tTimeOut = clock() + tDuration;
while ((_inp(SerPort+5) & 0x40) == 0)
if (clock() > tTimeOut)
I332Err = TimeOutErr;
return (0);
outp(SerPort,cCode);
while ((_inp(SerPort+5) & 0x01) == 0)
return (0);
return (_inp(SerPort));
#endif
} // ENDE: Funktion XmtSer
(4,293 Views)
We use the CVI library in an VC++ project.
Babak Pourat schrieb:
> Hello,
> First the history:
> // InitSer
> // Initialising.
> #ifdef CVI
> int iRet;
> return 0;
> #else
> word BdDiv;
> return (ParErr);
> if (SerPort == 0)
> return (IFCErr);
> return (0);
> #endif
> // CloseSer
> // Zweck:
> // close.
> #ifdef CVI
> #endif
> return 0;
> // XmtSer
> // Comunicate
> #ifdef CVI
> int iRet;
> #else
> if (I332Err != 0)
> return (0);
> return (0);
> return (0);
> #endif
(4,293 Views)
The ComWrt in CVI is an asynchronous command. This means that it runs on a separate thread. Thus, your main thread would continue to execute while on second thread the serial communication would occur. The time delays come from the Windows management of the threads. The threads compete for CPU time. There are several ways to improve the communication delay. One way is to increase the computer speed. With a faster CPU, your system should be able to respond faster. Another way is to reduce the number of threads that are running (close other applications). In addition, you could upgrade to CVI version 5.5.1. In the newer version of Labwindows the function ComWrt has an option to be run in synchronous mode. It means that the thread will wait until the communication
is complete.
Buddy Curtis
Joji
(4,293 Views)
> the communication is complete.
Where can I find this option?
Babak
(4,293 Views)
If you have LabWindows/CVI 5.5.1, you can specify a negative value for the Output Queue Size when calling OpenComConfig(). This makes write operations synchronous -- when ComWrt() or ComWrtByte() return, they have completed their output operations. I would recommend this as well as switching from ComWrtByte() to ComWrt(). To upgrade online to CVI 5.5.1, go to http://www.ni.com/upgrade and select upgrade to Measurement Studio 1.0.1.
Joji
(4,293 Views)
