LabWindows/CVI
problem with panels
HI
My system uses TS3.0 and CVI7.0.
I have created 3 panels, all in the same filename.uir and all have exactly the same size. In my application, I load the 3 panels into memory during the setup portion (of TS) without displaying them.
In the main sequence (of TS) I used DisplayPanel and HidePanel in order to show the approperiate one. (The 3 panel are located at exactly at the same coordinates).
Is there any problem doing that?
Is there any precocious I should be aware of?
Anyway, the problem appears at a certains place when i try to do DisplayPanel. It causes SystemException error (-17502). To make things worse, I'll add that sometimes (usually the first time) it does work and display the panel.
Any idea?
Meantime, I was chang
ing my applicatoin so that I will use only one panel. It seems to work that way, but I don't like this solution and prefer to be able to wrok with 3 different panels.
Rafi
(3,288 Views)
Hi Rafi,
I've seen similar before usually when trying to discard or open panels that weren't loaded in the same thread as they were loaded in.
This example may be useful...
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3F12356A4E034080020E74861&p_node=DZ52195
As should this one :
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B9290F6A3A2A4E9AE034080020E74861&p_node=DZ52000_US
How are you storing the reference to the panels? Is it a global in the DLL or are you not using DLL's?
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,288 Views)
Thanks Sacha,
I will study the examples in the following few days.
In my program, I load the panel in the 'setup' portion (of TS) and store them in globals in the DLL. I'm attempting to discard the panel in the 'cleanup' portion (of TS).
When it fails, I see error -129 when I'm attempting to discard the panel. It has something to do with multithreading (I geuss) which is weird because niether use multithreading, nor do I know to do it...
Is it possible that, somehow, without realizing it, I run more than one thread?
Rafi
(3,288 Views)
