LabWindows/CVI
problem with embedded uir files
I just stumbeled over a weird problem with a project that has it's uir files emebdded in the executable
(cvi 7.0, win XP pro).
The executable runs just fine as long as the user has admin-privlegues - if not,
I get a message telling me 'cannot access uir file - permission denied'.
this is in spite of the fact that the user has full read/write privilegues to the directory where the program ist located.
in addition, all goes well if I provide the uir file separately from the exe.
but this is just what I wanted to avoid by emedding them, thus avoid problems w. wrong version, missing file ets.
Once the game is over, the king and the pawn go back into the same box.
(3,363 Views)
This has already come up in the forum. The link to the thread is -
http://forums.ni.com/ni/board/message?board.id=180&message.id=12240#M12240
This should answer your question.
- jared
(3,359 Views)
thanks for the hint (I had searched the forum before but nothing found).
I also tried the proposed _putnev() workaround, but it didn't work either (probably due to caching, as mentioned).
is this problem fixed with cvi 7.1 ?
(3,337 Views)
