LabWindows/CVI
problem with a function write in a library
I am using the 26xx Library to communicate with a 2636B.
in the function "ke26xx_WriteSerialData (ketlhey, envoie); " , ketlhey is my device name and envoie is type : ViChar envoie [];
I am trying to write this : envoie = "*IDN?\n"; but it print the error : "  64, 24    error: array type 'ViChar []' is not assignable". I don't understand why i can't make it …. 😞
I find it easy to correct it but i Don't know how to do it.
Thanks you !
(1,372 Views)
Accepted by rolfk
In C char arrays are not assignable by default, use strcpy () instead, or change the variable to char *envoie (if further functions accept it).
(1,358 Views)
