LabWindows/CVI
printtextbuffer
Hi all,
i'm using printtextbuffer to print data in the buffer in a printer. The problem is that this function is adding caracters to the buffer which has an impact ti the data that i want to print. So, it's caused by the cal of this function?
best regards
(3,269 Views)
From the help I must point out the following caveats:
  • Newline/carriage-return characters are honored.
  • Tabs expand according to the current state of the ATTR_TAB_INTERVAL attribute. You can modify this attribute with SetPrintAttribute. The default tab interval is four.
  • Text that extends beyond the end of the paper either truncates or wraps, depending on the state of the ATTR_TEXT_WRAP attribute. You can modify this attribute with SetPrintAttribute. The default is wrap.
  • An ASCII NUL byte marks the end of the buffer.
The last one there could be of importance. Is your buffer null terminated (The last character in the string is a ASCII NUL or 0)? If not, then the function may be reading past the end of your string into garbage data until it hits a ASCII NUL character.
(3,254 Views)
