LabWindows/CVI
print in binary format
uint8 value = 5;
The "value" in binary format is "101".  How can I print it in binary format?  Anyone can help?  Thanks!
(3,622 Views)
The following code is targetted at converting a single byte into binary and setting a CVI string control accordingly, but I'm sure you will be able to adapt its ideas to suit your application:
void ShowBin (int ctrl, int val) {      // Display data in binary
    char str [9];
    int i, patt = 0x80;
    str [8] = 0;                        // Terminate string
    for (i = 0; i < 8; i++, patt >>= 1) // Repeat for each bit
        str [i] = val & patt ? '1': '0';    // Select a 1 or a 0
    SetCtrlVal (pan, ctrl, str);        // Update display
JR
(3,618 Views)
> uint8 value = 5; The "value" in binary format is "101".&nbsp;
> How can I print it in binary format?&nbsp; Anyone can help?&nbsp; Thanks!
So standard printf specifier, unfortunately.
See Question 20.10 in the comp.lang.c Frequently Asked
Questions (FAQ) list at http://www.c-faq.com/.
Guillaume Dargaud
http://www.gdargaud.net/
(3,603 Views)
