LabWindows/CVI
possible bug while a popup is open
I noticed a strange behavior for popup windows in CVI 2009: when a popup is open, and I click on a button on the caller panel (that I think should be completely inacitve) the EVENT_LEFT_CLICK_UP is generated.
I attached a simple application to show this behavior: in the textbox I append every event generated for the "Click" button. Before opening the popup you can see a lot of events (EVENT_MOUSE_POINTER_MOVE, EVENT_LEFT_CLICK, ...) when you click on this button.
If you click on "Open" a popup is opened; if you click on the "Click" button while the popup is open you will see that the EVENT_LEFT_CLICK_UP is generated.
Could you confirm this is a bug?
The same behaviour is shown for MessagePopup( ), ConfirmPopup( ) and InstallPopup( ).
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(4,599 Views)
Hi Vix,
Thank you for your posting.
I tested your example project and seen that you seem to be right.
The event EVENT_LEFT_CLICK_UP should not happen when a Modal dialog box is opened.
Now I'm sending a request to R&D in order to let them verify and take the right actions.
I'll let you know if they tell me that this is not a bug but a somehow expected behaviour.
Thanks again
Best Regards
Luca Gallo
Sales Engineer
(4,574 Views)
Hi Vix,
I'm just writing to tell you that the problem you've found has been recognized and reproduced by our R&D deparment and that the fix will be made in the next version (2010) of CVI.
Thank you very much for your interest and suggestion
Best Regards
Luca Gallo
Sales Engineer
(4,536 Views)
OK.
Thanks for your help.
Vix
Using LV from 7
(4,506 Views)
@luca Gallo wrote:
Hi Vix,
Best Regards
Can you post the car number?
(4,492 Views)
237405
(4,470 Views)
Thanks for the number.Smiley Happy
(4,372 Views)
