LabWindows/CVI
passing a variable type to a function
greetings,
i'm addressing an Ethercat device using the Beckhoff Twincat ADS dotnet library, that is linked into my project as an instrument i created.
The function in question reads an analog input into the variable whos handle i pass to it (&valueHandle1) , but also requires the variable type, of the type System_Type.
err = TwinCAT_Ads_TcAdsClient_ReadAny_1 (tc_handle, Var_handle1, UINT16,  &valueHandle1, &exception);
in C# the variable type is easily passed by e.g.     typeof(Uint16)
but i'm having difficulty in Labwindows.  i tried passing the variable type directly, without success.
This is the function proto:
int CVIFUNC TwinCAT_Ads_TcAdsClient_ReadAny_1(
                TwinCAT_Ads_TcAdsClient __instance,
                int variableHandle,
                System_Type type,
                CDotNetHandle * __returnValue,
                CDotNetHandle * __exception);
and my code is attached below.
Any help will be appreciated
Thys
(4,550 Views)
