LabWindows/CVI
passing a variable parameter to a single callback function
I have 10 command buttons which is linked to a single callback function.But I need to pass a variable parameter for each command button.ie  command button1( var=1),command button( var=2) etc... How can I do it.
Also I am going to create a thread everytime i click on command button.Is this a good idea to implement in the above mentioned way?
Please reply..
(3,292 Views)
I could solve it by using  creating an array (arr) with known  values. and calling
 SetCtrlAttribute( gPanelHandle,PANEL_COMMANDBUTTON_22,ATTR_CALLBACK_DATA,(arr+index));
This will solve the problem.
sorry for psoting it bfore thinkningSmiley Happy
(3,285 Views)
