LabWindows/CVI
out of bounds pointer error
Hi
when i run my cvi app, it pop-up error with this message:
Dereference of out-of bounds pointer: 1 bytes(1 elements) past end of array.
the relative code fo this error is
     for (i=0;i<32;i++)
          l_vArrayEGsmPwrCtrlLev[i]=l_vPwrCtrlLev[i];
and i  set the   variable declaration in *.h file for it is "int g_vArrayEGsmPwrCtrlLev[1][32]; "
Does anybody can help me?
thanks
crystal
(3,000 Views)
Hi Crystal:
I will assume that l_vArrayEGsmPwrCtrlLev and g_vArrayEGsmPwrCtrlLev are the same variable and the difference in names was a typo when posting this message.
The problem is that you have declared g_vArrayEGsmPwrCtrlLev as a two-dimensional array here:
and in you're loop, you are indexing on the first dimension when you meant to index the second:
for (i=0;i<32;i++)
<- This dimension has a range of [0..1].
You probably meant:
          l_vArrayEGsmPwrCtrlLev[0][i]
I am the founder of CnCSoftwareSolutions. When not cleaning up baby drool, I write about test data or work on Vision, a tool for understanding your test data. Visit me at www.cncsoftwaresolutions.com
(2,980 Views)
