LabWindows/CVI
omitting CAN library
I have a measurement program written in CVI that supports several instruments; communication is via serial, TCP, GPIB, or CAN interfaces.
Now I want the same program to compile (and run) on a computer that has no CAN instrument, and thus no CAN library is installed.
The executable has a configuration option that enables/disables CAN instrument support, so the lack of the instrument doesn't hurt if the switch is set properly.
The idea is that I can work on the program on my notebook as along as I do not need to work on the CAN related functions.
However, I cannot compile the code without the CAN library installed, because function prototypes exist that include constants such as NCTYPE - hence without the library I receive compilation errors.
Thanks for assistance,
Wolfgang
(3,574 Views)
I may add that NI-CAN is not supported on XP64, so there seems to be no possibility to work on my code as soon as I include the CAN library, even if I want to modify CAN-free routines only.
What I am looking for is a possibility to include a 'dummy library' or file that includes all NC-definitions once the CAN is unavailable, or a suitable macro etc. to disable all CAN-related function calls in my source code, permitting the compilation of the code for test purposes without the library.
Is it possible?
Thanks, Wolfgang
(3,554 Views)
Accepted by topic author Wolfgang
Presuming your CAN-related implementation is fairly isolated, one possibility would be to wrap all that code in a preprocessor conditional like #ifndef CAN_NOT_SUPPORTED. When developing on your laptop, you would add CAN_NOT_SUPPORTED to the compiler defines found under Options>>Build Options dialog.
Mert A.
(3,546 Views)
Thanks Mert! The compiler define (/DCAN_NOT_AVAILABLE=1) indeed did solve my problem! I only have to include a line
#ifndef CAN_NOT_AVAILABLE
in the include file of all my CAN functions, and all complaints of the compiler are gone 🙂
And I've got to know the compiler define feature...
Wolfgang
(3,534 Views)
