LabWindows/CVI
ocx file
I want to incorporate the components in this .ocx file that I have into a
labwindows project. I choose 'Create ActiveX Automation Controller' from
the Tools menu. I do not see that particular server (.ocx file) on the selection
menu, so I browse and try to add it. It gives me a 'Type Library not compatible
for ActiveX Automation'. Why is this so and how would I be able to work
with the vendor to be able to have these controls available to me?
(3,825 Views)
I think it's not enough that you have that ocx file but you need to register
that component into your system registry, the ocx component may need others
dlls or other files, Now I think the MS Visual C++ comes with some utility
named RegSrv32.exe which you execute from the dos command line and you supply
the ocx filename as an argument to that command, If the registration successed,
You should see that ocx from the CVI ActiveX automation server.
a>labwindows project. I choose 'Create ActiveX Automation Controller' from>the
Tools menu. I do not see that particular server (.ocx file) on the selection>menu,
Type Library not compatible>for
ActiveX Automation'. Why is this so and how would I be able to work>with
(3,825 Views)
I had already registered the .ocx file successfully using Regsvr32.exe, but
the file does not show up in the selection box as a registered server. When
I BROWSE and select my .ocx file, I still get the message, 'Type Library
not compatible for ActiveX Automation'. Is this because it is a .ocx file?
I've read elsewhere on some of the support pages that .ocx files cannot
be used and a .dll file should be created instead of a .ocx file in VBasic.
However I tried amovie.ocx in the system32 folder and it allowed me to see
the methods. What would I have to ask my vendor to do to allow me to access
the methods in his software?
ster>that
component into your system registry, the ocx component may need others>dlls
or other files, Now I think the MS Visual C++ comes with some utility>named
RegSrv32.exe which you execute from the dos command line and you supply>the
ocx filename as an argument to that command, If the registration successed,>You
should see that ocx from the CVI ActiveX automation server.>>>
wrote:>>>I want to incorporate the components in this .ocx file that I have
into>a>labwindows project. I choose 'Create ActiveX Automation Controller'
from>the>Tools menu. I do not see that particular server (.ocx file) on
the selection>menu,>so I browse and try to add it. It gives me a 'Type Library
not compatible>for>ActiveX Automation'. Why is this so and how would I be
able to work>with>the vendor to be able to have these controls available
to me?
(3,825 Views)
When you look closely you will find that CVI is NOT fully supportive of
ActiveX Comp. The word from NI is that it will be in the next release,
which is due sometime in 2001.
Richard.
Sheila Floresca wrote in message
news:389ee283@newsgroups.ni.com...
but
When
file?
VBasic.
> However I tried am
see
access
register>that
others>dlls
utility>named
supply>the
successed,>You
server.>>>
have
Controller'
It gives me a 'Type
Library
> to me?
(3,825 Views)
