LabWindows/CVI
ntdll error with CVI 8.1
Dear NI,
I am trying to run an application compiled with CVI 8.1, and I got the following windows error:
Title: Gui.exe-Entry point Not Found
Body: The procedure entry point Rtlipv4StringToAddressW could not be located in the dynamic link library ntdll.dll
OS: Windows 2000,  v5.00.2195, service pack 4.
I had the same problem with another machine using XP SP1.Installing SP2 solved the problem.
Thank you for your support.
Sincerely,
Ton Nguyen
(3,439 Views)
Hey Ton,
Check out this post and see if it helps. If that post doesn't help, let me know.
Best Regards,
Jonathan N.
(3,437 Views)
