LabWindows/CVI
ni report generation problem
When I use Ni report generation in CVI to print my test data, I found it's hard to make the column  in a line.
I generate PDF format file to display the print result, see attachment.
the following is my source code:
 char msg[255];
#define SPACING "       "   // 7 space, add by andy
 sprintf( titleFine, #%-10sSignal%-sAlarm Type%-10sLength%-10sRotation%-10sArea(%s^2)%-10sAmp-10%sDepth,
            SPACING, SPACING, SPACING, SPACING    SPACING, SPACING, "mm", SPACING, SPACING );
       for (i=0; i<count; i++)
 sprintf(msg, "%02d%s%9s%s%6s%15s%-6.1f/%-6.1f%s%-6.1f/%-9.1f%-15s%-6.0f%10s%-6.1f%10s%-6.2f",
                             i+1, SPACING, rollHeader.Out_SignalName[j],SPACING,
           inspectMode==BLOBPART_BRUISE ? MAIN_get_message(MSG_CSCAN_FLAW_LOWER) : MAIN_get_message(MSG_CSCAN_FLAW_UPPER),
        SPACING, (float)x1, (float)x2,SPACING,(float)y1, (float)y2, SPACING, area, SPACING, amp, SPACING,m_depth );
 NIReport_AppendLine (reportHandle, msg);
Work hard and enjoy life.
Love CVI and Labview!
Certified Labview Developer
(3,734 Views)
Try to use "/t" (not "SPACE" ), that is :
sprintf(msg, "%02d%c%9s%t%6s%15s%-6.1f/%-6.1f%s%-6.1f/%-9.1f%-15s%-6.0f%10s%-6.1f%10s%-6.2f",
                             i+1, '/t', rollHeader.Out_SignalName[j],'/t',
NI Applications Engineer
(3,708 Views)
Thank you!! I try to use "\t", but it doesn't work:Smiley SadSmiley Mad
 sprintf(msg, "%02d%c%9s%c%6s%c%-6.1f/%-6.1f%c%-6.1f/%-9.1f%c%-6.0f%c%-6.1f%c%-6.2f", i+1, '/t', rollHeader.Out_SignalName[j],'/t', spectMode==BLOBPART_BRUISE ? MAIN_get_message(MSG_CSCAN_FLAW_LOWER) : MAIN_get_message(MSG_CSCAN_FLAW_UPPER), '/t', (float)x1, (float)x2,'/t',(float)y1, (float)y2, '/t', area, '/t', amp, '/t',m_depth );
I also try to use as this, but it doesn't work:
sprintf(msg, "%2d\t%s\t%6s\t%6.1f/%6.1f\t%6.1f/%6.1f\t%6.0f\t%6.1f", i+1, rollHeader.Out_SignalName[j], inspectMode==BLOBPART_BRUISE ? MAIN_get_message(MSG_CSCAN_FLAW_LOWER) : MAIN_get_message(MSG_CSCAN_FLAW_UPPER), (float)x1, (float)x2,(float)y1, (float)y2, area, amp );
 Pls help me, thank many!
帖子被侠客在 12-09-2008 12:28 AM
时编辑过了
(3,702 Views)
I see your results, why not add in a table, you can use the cell to achieve the alignment with the table operation functions:
Start TableNIReport_TableStart
End TableNIReport_TableEnd
Append RowNIReport_TableAppendRow
Next CellNIReport_TableNextCell
Set Table Column WidthNIReport_TableSetColWidth
Get Table Column WidthNIReport_TableGetColWidth
Set Table AttributeNIReport_SetTableAttribute
Get Table AttributeNIReport_GetTableAttribute
帖子被Topkins在 12-09-2008 03:28 AM
时编辑过了
(3,690 Views)
Thank you very much.. I really appreciate your help!!
(3,674 Views)
