LabWindows/CVI
moving average
I work on CVI8.1. I'd like to make a moving average of a analog input signal. With DAQmxReadAnalogF64, I have read data in a buffer called gData and then I'd like to make the moving avarage of gData on 2seconds for example and have the result in an other buffer called mean for example.
I know "Mean" function (prototype: AnalysisLibErrType Mean (double Input_Array[], int Number_of_Elements, double *Mean);) but I don't want arithmetic average!
Can you help me?
Thanks.
Julien
(4,363 Views)
A simple moving average can be computed in a loop passing as input array your gData + offset and an appropriate number of samples to fit your 2 seconds:
for (i = 0, index = 0; i < totalsamples - 2SecWindow; i+= 2SecWindow) {
    Mean (gData + i, 2SecWindow, &avg[index]);
    index++;
(4,355 Views)
Thanks. but it doesn't work. 😞 I have some errors in my buffer size.
Can you see my project and explain me why it doesn't work.
Thanks a lot.
julien
(4,346 Views)
There is no problem now, I made a simple mean on my acquisition samples and I'll mean only time elapsed and real time frequency.
Thanks.
Julien
(4,301 Views)
