LabWindows/CVI
modbus connect with COM4
Hello all.
I created VI with MODBUS.
I connected MODBUS unit with COM4.
But I see in “VISA resource name”: ASRL1, ASRL4 …
How can I connect COM4 with MODBUS unit.
With respect
Aleksandr.
(3,382 Views)
ASRL4, ASRL4::INSTR and COM4 should all be aliases for the same resource (serial port 4 in your system). You can check in Measurement and automation explorer under Devices and interfaces >> Ports which are the ports available in your PC and their resource name and VISA name.
But please note that this forum is dedicated to CVI users: since it seems to me that you are developing in LabVIEW, you can find better support in its proper forum.
Hope this helps
Roberto
(3,378 Views)
Dear Roberto.
Thanks for the answer.
I installed the drivers and all begin to work
Best regards
Aleksandr
(3,315 Views)
