LabWindows/CVI
matlab standalone execute
By using Matlab compiler (MATLAB 7.0, R14), I create shared LIB to export matlab function to CVI.
In CVI 8.1 platform, it works fine in debugg mode. I can send measured data to Matlab for calculation and get results from matlab function.
After I build a excution file with CVI and install it on PC (Windows XP), I can run excution file. If I don't use matlab related function, the excution file is running without problem. As soon as I initiate matlab, the excution file is crached (excution file will be closed).
Can someone share me with your experiences on how to build excution file with CVI including matlab shared LIB? or any advices how to solve the problem.
Message 1 of 1
(3,200 Views)
