LabWindows/CVI
.m files to LabVIEW?
Is it possible to import .m files of Matlab,  directly in to LabVIEW?
(3,979 Views)
You should post that question to the LabVIEW forums instead of the CVI forums.
Best Regards,
Jonathan N.
(3,965 Views)
Hey ITA,
You can use the MathScript node for similar functionality.  This is described here:  Developing Algorithms Using LabVIEW MathScript: Part 1 – The LabVIEW MathScript Node
Also, the MathScript Node also describes this application.
(3,921 Views)
Thanks a lot!
(3,911 Views)
(3,904 Views)
