LabWindows/CVI
<io.h> not available in Windows SDK 8.1
I need to compile an external library which requires some functions from Windows SDK.
The library uses _access() which requires <io.h>.
I can't find <io.h> in the include folder of Windows SDK 8.1 installed with CVI 2017.
How can I fix this?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(4,609 Views)
Hello Vix,
io.h is not part of Windows SDK but rather VC runtime. You can use GetFileAttrs from Utility Library.
(4,571 Views)
Hi Constantin,
I don't know, but <io.h> is included in Windows SDK 10.
I opened a ticket with NI and I've been waiting for suggestion on how to update the SDK used by CVI 2017.
Vix
Using LV from 7
(4,562 Views)
One more thing;
the same library uses
gmtime_s()
too which exists in SDK 10 but doesn't exist in SDK 8.1.
I think the only reasonable approach is configure CVI to use an updated release of SDK.
How can I get this?
Vix
Using LV from 7
(4,549 Views)
The only solution to this issue is to push NI to update Windows SDK included with CVI.
Feel free to support this idea if you think it's useful.
Vix
Using LV from 7
(4,533 Views)
