LabWindows/CVI
locking the GUI
Is there a way to ignore GUI events .. .effectively locking it out?   My problem is that I have a list box with items in it. When the user clicks an item I perform an action that takes about 1 second to complete.  If the user clicks too much on the list box during this action the program will generate a GP failure.
I tried to block the events with an  ."  if (ProcessActive ==  0 ) { ... switch(event) {   " construct, but it doesn't help.  I once saw a function to lock out the GUI entirely, but don't remember the function call.
Phil
(3,243 Views)
Hi Phil,
A general rule of thumb is not to do anything time consuming in a UI callback. If the UI event needs to trigger a time consuming task, it is a good idea to have the UI callback launch a separate thread (e.g. CmtScheduleThreadPoolFunction) to do the task. If you don't move the task to a separate thread, your UI callback doesn't return until the task finishes. Doing the work in a separate thread allows your main thread to continue processing events, which means your UI is responsive, and your "ProcessActive ==  0" solution should work.
Mert A.
(3,241 Views)
Provided that Mert's suggestion is crucial, simply changing the control to indicator may help you to avoid control callback to be called when executing your long-lasting task without need to handle a global variable; control callback could then look like this one:
if (event != EVENT_COMMIT) return 0;
SetCtrlAttribute (panel, control, ATTR_CTRL_MODE, VAL_INDICATOR);
CmtScheduleThreadPoolFunction (...);
return 0;
After completion of the scheduled function you could PostDefferredCall a function to the main thread to restore normal control state.
(3,233 Views)
