LabWindows/CVI
line number in error messages
I make a number of IVI calls to varius instruments.  Recently I have experienced a seemingly random time out from one of the instruments.  I know what instrument is throwing up the error, but in the error handler, I would like it to report the source code line number where to IVI call occured so I can find which IVI call is causing the issue.
Here is the quote from the boss: "embellish our error checking macros with file name and line number macros. I know some compilers have them but not sure CVI does. This would help identify where these (and possibly others) errors come from."
(5,471 Views)
Accepted by topic author georgewbush
CVI offers __FILE__, __LINE__ and __ FUNCTION__ macros that are useful in these cases.
(5,465 Views)
THANKS
(5,459 Views)
Don't you have to activate the C99 option in [Options][Build Options] in order to get those pseudo-macros ?
(5,318 Views)
I am currently using CVI2012SP1 and don't need this option enabled to use __FILE__, __LINE__ and __FUNCTION__macros.
I know it was necessary to add a macro in 8.5 to enable those elements, but I tested now and as of CVI2009 c99 extensions need to be enabled to evaluate those macros.
(5,310 Views)
