LabWindows/CVI
labWindow/CVI real-time module replication tools
Labview realtime users have a replication tool and some vi related.
Do you know some CVI oriented tools (or documentation) to update programmatically an ETS realtime target?
Nicolas
(3,535 Views)
Nicolas,
NI does not currently have a programmatic API for setting up an ETS real-time target for a CVI Real-Time application.  However, we are currently working on this and plan to have something similar to the LabVIEW Real-Time System Replication Tools.
In the meantime, you must use NI Measurement & Automation Explorer (MAX) to setup an ETS target with the CVI RT software and NI RT device drivers.  You can use the LabWindows/CVI Real-Time File Copy Utility to download your RT DLL and support files to the target and to set your RT DLL as a startup DLL on the target.  The RT File Copy Utility can be run from the CVI environment or as a standalone executable.  The utility also has a command line interface you can use to run it silently from a script or your own application.  You can find documentation for the RT File Copy Utility in the CVI environment help.
-Jeff
NI
(3,516 Views)
I completly missed the LabWindows/CVI Real-Time File Copy Utility command line interface.
It covers a great part of my requirements.
Thanks a lot.
Nicolas.
(3,485 Views)
