LabWindows/CVI
invalid drive handle failed: Error # 30, using PCI card 1751 advantech
Please help me how to resolve this error?.,i am using window7 driver installed.device show in device manager property of my computer .
cvi labwindow code run on Xp window but error#30,invalid drive handle failed, occurse in window 7 ., .,window 7 differnt driver,.so i can change code and where?same code Xp window use for window 7? .,, .,if change then what ., .,where ., .,how.,?
(4,304 Views)
I'm not familiar with that error: is it happening in some function from Advantech? The situation you describe seems related to an incorrect installation of the board driver: you should check with Advantech support for the correct driver version to install and verify that it supports ANSI C development environments (I shortly looked into the Producer site and only saw listed C++ compilers: check that CVI is supported on Win7 too).
(4,263 Views)
Hi Amir,
I found another forum post where they encountered the same error:
PCI-1761 - Error code 30
http://forum.adamcommunity.com/viewthread.php?tid=517
They were able to solve it by ensuring they had selected the correct board ID.
Austin
Staff Software Engineer
NI
(4,243 Views)
Hi Amir,
One more question, is this PCI card made by National Instruments? It's not a PCI card I'm familiar with and it seems to be manufactured by Advantech. If that's the case, you may make more progress by reaching out to Advantech support.
Austin
NI
(4,242 Views)
