LabWindows/CVI
installation error
I am trying to install NI Developer Suite in Windows 7 in my notebook; just in the beggining appears an error window:
Error: Windows SDK function returned an error (eror code -12).
So I click OK and the installation goes on, until when I select the installation directory; at this point the same error window open and when I click OK the windows close...
(3,657 Views)
What version of developer suite you have? Windows 7 only supported afeter 2009 version with device drivers from nov 2009.
Abel
NI Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(3,635 Views)
You don't mention which version of Developer Suite that you are using, but it is most likely the following problem (and possible workaround):
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=463755#M463755
- WesW / NI
Message Edited by WesW on 01-06-2010 09:39 AM
(3,626 Views)
