LabWindows/CVI
input value + search file
I have some Problems now.
I will input a (File.txt) Name in my string window on my panel.
Then I will search this file on my Harddisk d:
I wrote this c-text, but my program did not found my file!
static char buffer[30];
static int result;
static IniText g_myInifile;
main...
int CVICALLBACK Suchen (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
GetCtrlVal (panelHandle, PANEL1_GEWNR, buffer);
result = FileExists("d:\\buffer.dat",0); //Exist File
if (result==0)
MessagePopup ("Werte", "Artikelnummer unbekannt. Es wurde keine Tastatur gefunden!!!");
if (result==1)
MessagePopup ("Werte", "Datei für
diese Tastatur wurde gefunden!!!");
break;
return 0;
Can s.b can my explain my mistake?
Thank you!
(3,134 Views)
In your routine you retrieve the file name input by the operator into the variable , next you look for the file:
With this statement, you are actually looking if a file named "buffer.dat" exists on D disk, not the file indicated by the operator!
If the operator inputs a full file name (with extension), you can pass it directly to FileExists function:
result = FileExists (buffer, 0); //Exist File
On the other side, if you are sure the operator inputs a file name without extension and you want to look for the file named .dat, you must appropriately format the filename to pass to the FileExists function, this way:
char file[MAX_PATHNAME_LEN];
sprintf (file, "d:\\%s.d
at", buffer);
result = FileExists (file, 0); //Exist File
But since you assume the operator has to input some value, maybe you can use the FileSelectPopup function which is powerful and restitutes a full pathname you can pass directly to FileExists function instead of simply asking for a filename.
Roberto
(3,134 Views)
Thank you Roberto for this good answer of my problem.
Greetings Thomas
(3,134 Views)
