LabWindows/CVI
include dll/lib/header
Hi all,
I'm using CVI7.0 and XP.
I included a external dll file(with header and lib).
I am getting
"xx.h"(52,19) syntax error; found 'identifier' expecting ';'.
"xx.h"(53,18) Redeclaration of 'USB_DLL_API' previously declared at xx.h:52.
From thid lines:
void USB_DLL_API fnSendZeroPacket(int iIdx);
int USB_DLL_API fnGetVersion(void);
void USB_DLL_API MTCSDllGetVersion(char* cBuf);
int USB_DLL_API MTCSInitSystem( char cTyp, int iVendorID, int iProductID );
how can i fix this?
any ideas?
thanks
(3,832 Views)
Looks like there is a definition missing. I would expect something like:
#define USB_DLL_API __stdcall
This, or something like it, should be found within the header files accompanying the dll.
JR
(3,828 Views)
hi ,
thanks for your help. i found the problem.
i defined the usb_api_dll after including the header.
newbie mistake 🙂
(3,827 Views)
Hi Bensai,
I just got curious when I saw "USB_DLL_API" in your post.
Can you tell what is that DLL is supposed to do?
I am in need of a good USB library compatible with CVI. Can it be use to send and receive data bytes to/from a USB port?
S. Eren BALCI
IMESTEK
(3,816 Views)
Here is more information on NI VISA USB facilities which you may find useful
JR
(3,805 Views)
