LabWindows/CVI
implicitly declaring C library function
I am currently working on a project where a program has been entirely written for Lab WIndowsCVI 2010 and the program worked.
Now we have done an upgrade of Labwindows CVI 2010 to Labwindows CVI 2013 and the program that before worked now give me these errors:
 main.c - 5 errors
  108, 13    error: implicitly declaring C library function 'index' with type 'char *(const char *, int)'
  108, 29    error: non-object type 'char *(const char *, int)' is not assignable
  109, 54    error: cannot increment value of type 'char *(const char *, int)'
  300, 27    error: non-object type 'char *(const char *, int)' is not assignable
  1162, 14   error: non-object type 'char *(const char *, int)' is not assignable
Build failed.
It looks I have a variable called index and this variable is maybe declared as a table like that : ssize_t index[]
in a file h.
My questions are:
-> How can I know where my variable is declared? Is there a shortcut for that? The program is very long there are many files .c and .h.
-> Is there an option in LabWindows CVI 2013 to make a compatible conversion of the written program from Labwindows CVI 2010 to Labwindows CVI 2013 ?
Thanks for your help,
regards,
Fabien
(7,024 Views)
I just precise that when I double click on the variable in my main.c, I then press CTRL+I and I see that my variable index is in many different files .h and .c but each time it's a parameter, I cannot see where it is defined.
(7,022 Views)
There are some changes and even incompatibilities of CVI2013 with earlier versions due to the use of a different (better) compiler. You can find them here.
One is that you cannot name a global integer variable index. Using index as a global variable will result in a compiler error: redefinition of 'index' as different kind of symbol. You must rename index to work around this.
(7,014 Views)
Thanks for your reply and for inform me about the difference between CVI 2010 and CVI 2013,
I couldn't find where my variable index was declared. So I tried to declare "index" as static int in the main.c and now it works.
I guess it may causes some problems since that maybe index is declared inside a librairy or any other file called by a librairy. And if that file is missing on my compute, it may causes some problem but the truth is that I have no compiler error.
Fabien
(7,005 Views)
What is the reason for 'index' now being a reserved keyword ? What is it used for ?
(6,967 Views)
Hi, gdargaud
index is a function defined in the gnu c standard library. According to the linked document, index is only around for compatibility, and it does the same thing as strchr.
Daniel Dorroh
(6,947 Views)
