LabWindows/CVI
imaqsnap trigger timeout
How can I use the snap function with trigger configuration to avoid the "non-fatal error" that appears when no image was token before timeout?
I explain :
I configure my acquisition for a trigger acquisition with the "imgSessionTriggerConfigure2" function. This function defines a timeout value that specifies the amount of time in milliseconds to wait for the trigger to occur and the image to be captured. When I use imgSnap, if the trig doesn't occurs, a non-fatal error appears after this timeout.
I could use the release version but I need debug version for the rest of my program.
I could put a higher valuer in the timeout but it block the program until trig is detected or until the error appears. Therefore, higher value doesn't solve my problem if I doesn't have any trig detected.
Thanls for your help,
Seb
(3,485 Views)
Look at the help for
SetBreakOnLibraryErrors()
Set BreakOnProtectionErrors()
SetBreakOnFirstChanceException()
By bracketing statements that have runtime issues with function calls to disable/re-enable error checking you can ignore issues in routines that do not required error checking.
(3,467 Views)
OK Thanks
(3,445 Views)
