LabWindows/CVI
imaq function panels
Are there FP's somewhere for the NI-IMAQ library so we can get function panel support from CVI while developing?
I can't seem to find them anywhere.
I don't see the IMAQ library listed in the project window like all of the other NI libraries - did we fail to install correctly?
Menchar
(3,405 Views)
Hello Menchar,
Thank you for contacting NI Support.
Yes there are IMAQ FPs available for Labwindows/CVI.  The presence of these is dependent on the installation order of your software.  I recommend re-installing your Vision Acquisition SW (contains NI-IMAQ etc.) which should make those librairies show up.
Let me know if this does not work.
Rishi L
(3,377 Views)
I can't reload VISION because that would pull in the 8.1 CVI RTE and we need to use the CVI 8.0 RTE.
Is there any way to load just the FP's?
Menchar
(3,375 Views)
Hi Menchar,
I was browsing the forums and see that you have a similar post located here., and that it was answered by Greg Stoll who is one of my R&D colleagues.
Did his solution work?
It would be better if we can keep your issue with the Vision RTE and CVI 8.0 in just one thread.
Let me know
Thanks!
Rishi L
(3,351 Views)
