LabWindows/CVI
i want to get float input from numeric control and then save it in four bytes
i want to get float type input from my numeric control for example (34.7462732738 ) and then save it in 4 bytes for sending 4 bytes to serial port kindly guide me, i have idea about integers in which shifting right 8 bits and storing data to byte by byte but is this possible for float ,  i want simpler and smarter solution so that i dont loose precision of my float.
thanks in advance.
(5,240 Views)
You need to investigate the use of unions wrapped around a typedef. Something like this I would suggest:
typedef union
 float Float;
 unsigned char Bytes[4];
}FloatByte_t;
void FloatByteTest(float Float, unsigned char *Byte1, unsigned char *Byte2, unsigned char *Byte3, unsigned char *Byte4)
 FloatByte_t FloatByte;
 FloatByte.Float = Float;
 *Byte1 = FloatByte.Bytes[0];
 *Byte2 = FloatByte.Bytes[1];
 *Byte3 = FloatByte.Bytes[2];
 *Byte4 = FloatByte.Bytes[3];
Kevin
(5,227 Views)
I can't test it now but I would try something like that:
float  f;
f = 1.23456;
ComWrt (port, (char *)&f, 4);
Of course you will receive a IEEE float on the other side of the line so you will need to cast it to the appropriate format to obtain the float.
(5,215 Views)
:manhappy: Proven Zealot :manhappy: please can you guide me in detail i am unable to understand , first i want to store in byte array and then write on com port
(5,205 Views)
I am now out of office without CVI to test with, but the idea I suggested was along this line:
  • (char *)&f    treat the memory pointed to by &f as a char array, and
  • ComWrt   send it to the com port
If you want to split this it two tasks you can use memcpy to fill a string with the raw content of the float variable, then write that string to the com port (WITHOUT using strlen operator!).
(5,185 Views)
