LabWindows/CVI
html editor
Hello all,
Are there solutions to edit a sring in the html format in an edit box with CVI?
I know there is an activeX server to edit html web file but I didn't  find solution to edit directly an html string.
Thanks by advance for responses.
Regards.
Nicolas
(4,150 Views)
What do you mean by "editing html in an edit box" ?
Message Edité par Maxime MULLER le 08-21-2008 10:52 AM
(4,120 Views)
Sorry, my explanation wasn't clear.
In fact, I need to show html code (for example : <div class=rela> RelaisOn <BR></div>) by using an html editor or viewer in a control.
I found the ActiveX server "DHTML Edit Control for IE5" that permit to edit Html code or file, but not to show html code sent by another program.
I think I need an activeX html viewer that can work both html files and code.
Thanks for your help
Regards
Nicolas
(4,115 Views)
Actually NI doesn't provide any HTML editing/viewing controls. As you said, there must be several ActiveX servers that have this feature. But in CVI you won't find any native control that does this.
(4,098 Views)
