LabWindows/CVI
hsdio generation buffer cyclic
Hi There
Is it possible to make the hsdio generation memory cyclic.
The purpose of that is to continuesly generate new data that is mach larger than the on board memory size
Thanks for advance
Gabel Daniel
(3,128 Views)
Hello Gabel,
I am a bit unclear about your question; are you referring to the behavior of the FIFO buffer?
Eric
Eric Liauw
Senior AE Specialist - Automated Test | CLD | CTA
(3,111 Views)
Hello Gabel,
I have a couple of additional questions.
What particular piece of HSDIO hardware are you using?
Also, are you using a particular CVI example for this generation task?
Eric
Eric Liauw
(3,108 Views)
