LabWindows/CVI
how to printf() to shell (cmd.exe)
is there any way to direct the output from 'printf()' function to the calling environment - namely cmd.exe ?
purpose: I'm writing CLI programs in cvi which works fine for parsing command line arguments etc... but I would like to have the output from printf() statements go to the command interpreter (cmd.exe) from which the program was called, e.g. for use in batch-files, pipe to other programs etc.
the normal behaviour for printf() is to open a separate window and display output there, which is pretty much useless in my case.
Once the game is over, the king and the pawn go back into the same box.
(8,671 Views)
Are You buildung a console application?
Target Settings... -> Create Console Application
/* Nothing past this point should fail if the code is working as intended */
(8,661 Views)
ok,
thanks, I remember having used this option before ... 🙂
what I want, is an application which comes up with the GUI when called without cmd-line arguments,
otherwise behave like described in the OP.
I'll check if this is possible...
(8,654 Views)
just for the record:
console application is ok for both mentioned purposes.
it just opens a console also when running in GUI mode.
(8,632 Views)
