LabWindows/CVI
how to play "beep" sound from PC Speaker
I used the Beep function in CVI,but the sound card generates the BEEP soud. I want to the PC Speaker generates the BEEP sound. Please help me. Thank you.
(6,641 Views)
If you have a console application, then: printf ("\7"); will do the trick. Unfortunately in a GUI based project this method will also leave a console window visible afterwards...
JR
(6,640 Views)
The Windows SDK defines a function named Beep(), which allows you to play a specified frequency for a specified amount of time on the PC speaker.
if it is not already done, you need to install the Windows SDK which is bundled with CVI, and of course, #include <windows.h>.
(6,632 Views)
yes,I used the Beep(),but no beep sound on PC Speaker. There is beep sound on the sound card.
(6,597 Views)
Accepted by topic author ghfirst
The Programmer's Toolbox (toolslib\toolbox\toolbox.fp) provides StartPCSound() and StopPCSound(). They should do.
/* Nothing past this point should fail if the code is working as intended */
(6,591 Views)
Yes,You are right.It is ok. Thank you very much.
(6,558 Views)
