02-24-2016 04:53 AM
I need a solution to command a 3 axis robot with step by step motor and labwindows/CVI
02-24-2016 05:21 AM - edited 02-24-2016 05:21 AM
A good starting point can be the NI Motion Control page: there you can find the solutions offered by NI for controlling motors.
There are also third-party alternatives that you can integrate into CVI: I have used solutions based on serial, Modbus, CAN, CANopen and with DLLs to call by the IDE.
In my opinion the best approach is to search for the motor+driver solution that best fits your needs, next investigate if it can be controlled by CVI (99% it will).
