LabWindows/CVI
how to avoid Space bar generates the commit event
I am using LabWindows/CVI Version 6.0.
The EVENT_COMMIT is generated when user press the <Enter> or <Space> if the active control is a command button.
My question is : is it possible to prohibit the Space bar generating the commit event in this case?
(3,303 Views)
You should catch the keypress using the EVENT_KEYPRESS event in the callback function of the control. Check if the keypress is <Enter> or <Space> and if so, swallow the keypress using the SetKeyPressEventKey function:
  case EVENT_KEYPRESS:
   if (GetKeyPressEventVirtualKey (eventData2) == VAL_ENTER_VKEY ||
      GetKeyPressEventCharacter (eventData2) == ' ')
    SetKeyPressEventKey (eventData2, 0, 0, 0, 0, 0);
   break;
Hope this can help you further.
(3,299 Views)
It works fine. Thank you very much.
(3,293 Views)
