LabWindows/CVI
how do we assign C Structure char value to labview LStrHandle data type
I am building .lsb file from CIN code in VI file. In CIN code I have structure with char[32] datatype. I have LStrHandle String data type in Labview to which I need to assign the value of char[32] of structure variable. When I do strcpy(lstrHAndle data variable,structure variable) .I try to run the VI it crashes and gives memory default error.
Can anyone guide me how to assign structure char[32] value to LStrHandle data type.
(6,715 Views)
It's difficult to tell from the limited amount of detail given, but you will most propably have to use a pointer. If you assing values to a structure member you can either use structure.member notation or a pointer notation structure->member.
What does the structure look like and how is it initialised and declared?
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(6,712 Views)
The LStrHandle data type is a pointer to a pointer to a structure that contains two elements: a numeric that indicates the size of the string; and the string. This structure resides in the LabVIEW memory space, so you must have LabVIEW initialize that string before you can assign any valu in your C code.
Here is some general pointer to what you can do:
1.-Initialize an array of 32 U8s in LabVIEW.
2.-Flatten the array to string.
3.-Pass this initialized array to your CIN.
4.- In your C code dereference the string handle until you get to the actual string.
5.-Do a memcpy() of your buffer to the buffer contained in the structure.
6.-Return the LStrHandle.
You can also initialize the LabVIEW string in your C code, but it requires the use of the me
mory management functions and it's much more complicated.
I hope this gives you a starting point. Please let me know if you have any further questions.
Juan Carlos
N.I.
(6,712 Views)
I had that problem too, the thing you have to understand before is that a LStrHandle DATA, is composed by two sectors, the characters chain, and the size of it.
For example:
#include "extcode.h"
#include "hosttype.h"
#include <string.h>
MgErr CINRun(int16 *Value, int16 *Numeric, LStrHandle labviewstring,
            LVBoolean *findFIRSTerr, int16 *SizeFindFirst);
Char value[32];    // or  char *value;
Short size;
Size=strlen(value);
memcpy(LStrBuf(*labviewstring),value,32)
or
memcpy(LStrBuf(*labviewstring),value,size)
or
strncpy(LStrBuf(*labviewstring),value,size)
and after that you should do this too.
LStrLen(*labviewstring)=size;
This works good, but lately in a random way I get the memory crash, what I think is happening is that I have to initialize the LStrHandle before using it because its pointer get sometimes a reserved sector of memory and it crash, my question is how to create and initialize a LStrHandle data, in C?Smiley Wink
Ing. Jorge M. Gamboa
Departamento de Mecatrónica
Tec de Monterrey
e-mail: ing.gamboa@gmail.com
(6,370 Views)
