LabWindows/CVI
how do I compile my cvi project including a vc++ library
Hello
I'm doing a cvi project that needs an external library compiled with c++.  This library is the winpcap library.  I'm trying to make a program that can use an ethernet device.  When I compile the project, it seems that cvi doesn't understand the definitions and symbols that are in the .lib file.  I've read about it in the help and I have learnt that .lib files are cvi library files, not the c++ ones.
So, ¿how can I use a library compiled in c++ with cvi?  Or much better, how can I read from and write to an ethernet card to do my own ethernet packets?
Thank you
Carlos Arcediano del Amo
(3,855 Views)
here you have information about how to integrate a Visual C++ DLL into CVI. Maybe, you have forgotten something. Really, the .lib file is a necessary file for CVI to integrate external code. This file can be even created by CVI. You have this information in the second link
http://zone.ni.com/devzone/conceptd.nsf/webmain/23b41e710ae65ed88625686900620da7#3
http://zone.ni.com/devzone/conceptd.nsf/webmain/1d0c73348d50de5486256faf00614757#7
Moreover, if you are getting some linking errors, it could be due to the following:
http://digital.ni.com/public.nsf/websearch/6A381D116E127FBE862566890072B3AE?OpenDocument
Finally, you also could have an alternative to winpcap. You might use winsock2 in order to open raw sockets.
I hope this helps.
crisR
(3,835 Views)
Hello, crisR
I've read the links you sent me and they work, but... my VC compiler is not configured to be compatible with CVI (or vice versa), I get this error:
 2 Project link errors
     Undefined symbol '_EnviaPaqueteSingleton@16' referenced in "probando_dll.c".
     Undefined symbol '_AbreDispositivoSingleton@8' referenced in "probando_dll.c".
In the pages you sent me I have read this:
Note: If you receive a project link error when running the project in LabWindows/CVI, verify that all libraries are included in the project. If all libraries are included, verify that you are using the compatibility mode that corresponds to your third-party compiler.
Well, ¿how can I make my compiler compatibles one with each other?
(3,831 Views)
Hello
I have solved the problem.  it is because I have defined the functions as extern C but I haven't put that directive when I have wrote the function in the .c archive.
(3,815 Views)
Ok. This is fine. Anyway, you can choose the compatibility mode in Options-Build Options menu.
Here, you can change between Visual C++ and Borland C++.
Congratulations.
crisR
(3,809 Views)
