LabWindows/CVI
how can i save a data in text format
how can i save a data in text format in labwindows cvi
Message Edited by Tikoy on 04-14-2010 11:30 PM
(3,119 Views)
Accepted by topic author Tikoy
If your data is in an array, the easiest way is to use the ArrayToFile function.
It automatically creates a file and puts your data in it according to the format you provide.
If you have individual samples that you need to write once in a while, you can either collect them into an array and then use ArrayToFile or open a file with fopen and write them as they are acquired with fwrite.
Hope this helps,
S. Eren BALCI
IMESTEK
(3,112 Views)
