LabWindows/CVI
help error in tmpnam
Hello NI,
I just came across an error in the CVI help of the ANSI C library function tmpnam: There is a link to the 'remove' function...
Note It is necessary to use the remove function to remove such files when no longer needed. This must be done before program execution is terminated.
This link is wrong Smiley Wink It ends up in the localtime function...
(Using CVI 10)
(3,138 Views)
Accepted by topic author Wolfgang
Wolfgang,
Thank you for bringing this to our attention. We will fix this documentation error for the next release of CVI. The link should be pointing to remove( ) which is in the same library as tmpnam( ).
(3,122 Views)
Thank you for fixing it Smiley Wink
(3,118 Views)
