LabWindows/CVI
graph portion of array
Hey everyone,
I'm using the 3dgraphcontrol.fp to display x and y coordinates versus output. I have those values correspond to each level in the physical z direction as well. I set up a ring control to the 3d graph so that the user can switch between the different z values. All of my data for x, y, z, and output are in arrays. Is there a way that I can graph only part of the arrays. If I graph the whole array of x and y, the data displayed is for all values of z. I want to split it up so that only the x, y, and output values are displayed for the selected z value in the ring control. Is there a way to do this? Thanks.
(3,169 Views)
Hi ACowans,
Are you using 4 ID arrays where each point has a x, y, z, and output coordinate?  if so, I would recommend looping through all of the arrays simultaniously, and create a new array containing only points with a specified z value.  This way, you can plot the new array which will have only relevant points.  There are a few different methods of handling 3d data, so if youusing a different one from what I described, let me know and we can work from there!
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,130 Views)
