LabWindows/CVI
getfiledate for API
hello all,
I want to get creation date of file,CVI using GetFileTime() to get date of file,but I think it is last access time date.So I want using API function to get it.
When I using GetFileTime(HANDLE(*)FILE,CreationTime,NULL,NULL), CVI compiler display error.It will always using GetFileTime include utility.h.
Can I using this function just defined include windows.h?(I can't remove utility.h because I using Delay() and so on.)
Thanks for you help.
(3,551 Views)
Hi Danny,
See the
Calling a Windows SDK Function That Has the Same Name as a LabWindows/CVI Function KnowledgeBase as this should provide the answer you are looking for.
Best Regards,
Jonathan N.
(3,540 Views)
thanks.
(3,529 Views)
