LabWindows/CVI
gain full access to a pci device
I need to access a pci device I/O space.
Can it be done with CVI?
(3,023 Views)
It sounds like you are writing a device driver. CVI provides some low level I/O functions that let you access memory for devices already configured by the OS, but it won't actaully configure the PCI device for you. You would still need some way for the OS to detect your PCI device and map its IO and memory space. so I would recommend using VISA for creating your driver instead of the low level IO functions. VISA is a driver that comes with a CVI API and is created for this purpose. See this document for how you would use VISA for this.
I hope this helps
Bilal Durrani
NI
(3,012 Views)
