LabWindows/CVI
ftexttopath example needed
I'm trying to run a labview dll from CVI.  I think I've got it all working expect that I have to pass in a Path variable.
Following the advice found in http://forums.ni.com/t5/LabWindows-CVI/Path-data-type-convert-in-CVI/m-p/699765/highlight/true#M3544...
I think I'm setting this up correctly, but the call to FTextToPath is still returning a 1 ("An input parameter is invalid.")
sample Code:
int CVICALLBACK Go (int panel, int control, int event,
      void *callbackData, int eventData1, int eventData2)
   MgErr err=-1;
   Path pathy;
   char wavePath[500]={"C:\\chewie_talking-ringtone.wav"};
   switch (event)
      case EVENT_COMMIT:
         err = FTextToPath(wavePath, strlen(wavePath), &pathy);
         // Call to labview DLL here
         break;
   return 0;
 I'm assuming it's something obvious I'm missing, but damned if I can see it.
Any input is appreciated!
(3,372 Views)
Hey MarksAlias,
On the line where you declare wavePath, it shouldn't be necessary to include the curly braces { } around the path. That's the only difference that I can see between your code and the one you linked.
Also, I noticed that an easier solution presented in that forum was to change the LabVIEW DLL to accept a string instead of a path. Is this possible for your application? If so, it might be a bit easier than doing it with these LabVIEW memory manager functions.
(3,353 Views)
Thanks Daniel.
For now I've resolved that specific issue.  The code actually works but the labview rte wasn't being initialize properly because the system was out of memory.  A call to LVDLLStatus confirmed this.  Not sure why the FTextToPath err returned was 'invalid parameter' but I guess that's just part of the rte not being loaded.
Thanks!
Mark
(3,348 Views)
