LabWindows/CVI
frequency measurement
I wanna measure sinewave frequency which is  acquired  from soundcard using AmpPhaseSpectrum() .
But the resolution is +/-50,eg.the input frequency is 920Hz,the measurement is 900Hz.
The belowing is the part of my rountine.
Tempdata[] is the data acquired from soundcard,len is the length.
Can you help check?Or is there other solution to measure?
 for(i = 0;i < len ;i++)
  Tempdata[i] = tem[i];
 status = AmpPhaseSpectrum(Tempdata,len,DISABLE_OPTION,interval/(double)len,amp,phase,&df_Amp);
 for(i = 2; i<(len/2);i++)
  if(amp[i] > amp[j])
   j=i;
 SetCtrlVal(PANEL,PANEL_FRETESTED,(double)(j*df_Amp/2));   //Display the frequency输入频率
Message 1 of 1
(3,063 Views)
