LabWindows/CVI
free a pointer to pointer
Hi
I'm using a two dimensional to store data, but when i have to define the array i don't know the dimensions of the array yet, so i have to use a pointer to a pointer to define the size of the array i want. I do the next:
        int **arraySegment = NULL;
        arraySegment = malloc (Conf.Vision.numLines*sizeof(int));
        for (x = 0 ; x < Conf.Vision.numLines ; x++)
                arraySegment[x] = malloc (Conf.Vision.numImages*sizeof(int));
So when i want to free arraySegment what do i have to do? Is it enough to use free (arraySegment); or do i have to do something like:
                free (arraySegment [x]);
any suggestions? Thanks
(3,852 Views)
Every malloc() (or equivalent type of function eg calloc()) needs a corresponding free(), so yes you do need to use the code you suggested. (Strictly speaking you are allocating space for pointers, not integers - you might want to tidy up the sizeof() statements accordingly.)
JR
(3,839 Views)
Thank you JR, one question what do you mean with "Strictly speaking you are allocating space for pointers, not integers - you might want to tidy up the sizeof() statements accordingly" that i should change the code in the first malloc because is not a reservation for int but for another pointer? something like:
        arraySegment = malloc (Conf.Vision.numLines*sizeof(int*)); (can i do this?)
Regards
Juan
(3,812 Views)
Indeed you can do that. And you can do it on your last line as well, with the second malloc() in a loop.
JR
(3,791 Views)
Thank you for your help JR
Regards
Juan
(3,768 Views)
