LabWindows/CVI
flash fscommand + CVI
I am trying to have CVI talk to flash.
So far, I have flash talking to CVI:
in y flash code, I have:
  fscommand("flashMessage", "Hi CVI!, this is flash talking");
and in CVI:
/* the callback */
HRESULT CVICALLBACK foo (CAObjHandle caServerObjHandle,
                         void *caCallbackData,
                         char *command,
                         char *args)
    SetCtrlVal(panelHandle, PANEL_STRING, args);
    return 0;
/* this code is located in the main function, it install the FS callback */
if ( (status = ShockwaveFlashObjects__IShockwaveFlashEventsRegOnFSCommand (flashHandle, foo, NULL, 1, NULL)) != 0)
                ReportAppAutomationError(status);
This works fine.
Now I would like to have it the other way arround: CVI sending messages to flash?
How do I do this?
I think i know what i should write in flash (from http://www.flashfanatiker.de/blog/archives/000032.html )
but I have no idea of what I should write in CVI.
Thank you for your help.
(3,177 Views)
Why do not use ActiveX
here is an example
Using the Macromedia Shockwave Flash Player ActiveX Control in LabWindows/CVI
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=BC14007242F726F4E034080020E74861&p_...
Alexandre D
(3,135 Views)
