LabWindows/CVI
filter iir
Hi! Excuse me for language.
I must create an a filter iir in C that it clears the input signal.
Can you help me? Thank you very much.
(4,222 Views)
Hi!
   If you have advanced analysis library it is not really difficult.  Go to LabWindows menu,
          Library --> Advanced Analysis -->  Signal Processing --> IIR digital filters
   and explore the functions you have.
Anyway, if you are new to DSP and digital filters, be careful in using IIR filters: they have to be carefully designed and tested, and they can show unstable behaviour.
greetings
graziano
(4,219 Views)
If you want to implement the filter in C (I mean, without Advanced analysis library), you can refer to on-line book "Numerical Recipes in C"
                           http://www.library.cornell.edu/nr/cbookcpdf.html
  especially this chapter:    http://www.library.cornell.edu/nr/bookcpdf/c13-5.pdf
Bye!
graziano
(4,211 Views)
Thank you! I will see it. I hope it is efficient for me.
Grazie ancora - bye
(4,169 Views)
...magari il prossimo post lo scrivo in italiano!
Ciao, e buona giornata!
graziano
(4,163 Views)
🙂 Infatti, per questo ho scritto "grazie ancora", perchè avevo intuito dal nome che sei italiano.
(4,148 Views)
