LabWindows/CVI
fatal error in script
I am getting a fatal error at script line 1087 "unable to open destination
file" when trying to install my cvi project under win98. It works fine under
NT. What should I do?
(3,692 Views)
"Rick Bernstein" wrote:
>>I am getting a fatal error at script line 1087 "unable to open destination>file"
when trying to install my cvi project under win98. It works fine under>NT.
What should I do?
Hi Rick,
One thing that you can check up for , is to make sure that you have a Temp
directory on your machine, where you are installing the program.
You may also want to set a Temp environment variable in autoexec.bat before
you
try to install anything..
Hope this info help....
nandan dharwadker
Nandan Dharwadker
Staff Software Engineer
Measurement Studio Hardware Team
(3,692 Views)
