LabWindows/CVI
extern FILE*
Ok im trying using the pointer in another file, how can I do it?
in the main file its declared as FILE *fileptr={0}
will I do this FILE extern *fileptr in the main file
and the othe file where i want to use it will i just char *fileptr={0};
how will i do this using extern with FILE pointer
(5,498 Views)
You probably have a common header file for your application - add the following line to it:
    extern FILE *fileptr;
All your source files will of course #include this common header file. In just one of your source files, you need to actually declare the object, initialising it as well if you like:
    FILE *fileptr = NULL;
The variable is now available to be used by all the source files that #include the header file. Of course, your sequence of execution needs to guarantee that the value of the variable is set correctly before any module reads it.
JR
(5,485 Views)
thanks for your help.
(5,474 Views)
